front license plate question - FirebirdV6.com/CamaroV6.com Message Board
  • front license plate question
    I figured the lounge was the best place for this, gota a question for all you who have a front license plate on a 98+ firebird. First off how do you get the stock firebird cover off?
    Second, once you get it off are the screw holes already there to mount a license plate. Reason i ask is that I currently live in Louisiana which doesn't have front plates but will be moving to Texas within the next 6-8months and was curious.
    -Brad
    2000 V-Star Custom 1100
    :rock:
    Actually Brad, this is a good General Tech question. So I'm going to shuffle this over there.
    Steve
    FirebirdV6.com/CamaroV6.com Administrator
    Stupid is rewarded with the ban button.
    Official Avatar Nazi according to Meatyshells :D
      cool
      :cool:
      -Brad
      :rock:
        I have no idea, but hi Brad [img]smile.gif[/img]
        Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
          hi jessica, [img]smile.gif[/img]
          come on now somebody out there has to have the answer to this, I'm almost positive camaro's have a bracket but what about birds?
          -Brad
          :rock:
            I havent removed it either. It looks like you just have to start removing the nose. I did not see anything in owners manual to tell how either. Maybe a dealership will know...
            Good question. I am also surprised that this has not shown up in searches as already being discussed. I don't want to find out the hard way that it is not push pins holding the plate on. [img]graemlins/omg.gif[/img]
            01 Firebird A4 3.42
            Powerdyne @ 6 PSI
            and other mods
              do you not just pop it out?
              I live in texas, but I don't use my front plate.. lol
              2001 S.O.M. Firechicken 3.8L V6, auto.
                Mine cover just popped out but yes the holes are already drilled in it for you and mine also had the screws in the holes for the plates but I bought mine used
                <a href=\"http://www.cardomain.com/profile/blackfbird_98\" target=\"_blank\">http://www.cardomain.com/profile/blackfbird_98</a>
                  hmm I have tried popping it out it seems to slide out on the top pretty easily but remains attached at the bottom, I guess so long as there is no bracket needed I can get the cover off one way or another when the time comes.
                  I plan on running my front plate all the time just to avoid having to deal with a po po having a bad day. I think it looks like crap but oah well when the time comes no biggie.
                  thanks for the responses
                  -Brad
                  :rock:
                    there are 2 screws at the bottom of the plate, they are little star screws. remove those first, then it should come out pretty easily
                    2002 Pewter Metallic Pontiac Firebird<br /><br />Mods: 3\" Borla Catback Exhaust, SLP Cold Air Intake, Removed Air Silencer, K&N Filter....more to come.....hopefully...
                    • Andy H
                      Transmission removal help!!
                      by Andy H
                    • 2.8 Bird
                      Abs inop
                      by 2.8 Bird
                    • fishin
                      by fishin
