Oil starvation - FirebirdV6.com/CamaroV6.com Message Board
Oil starvation
  • Oil starvation
    If an engine was run dry what would be the problems?
    I'm sure I can think of alot.
    Just Curious!
    Re: Oil starvation
    I can think of bearing failure. piston ring failure. overheating. the list probably goes on and on...
    probably best to get a used engine than rebuild it huh?
      Re: Oil starvation
      You can take a deeper look into it, but it can literally and I have seen the pistons melted inside the block from lack of oil AND high temps. Now this engine imparticular was low on oil a bit had a weak pump,and was driven at 5k rpm for about 20 minutes, but its one of the many things.
      Take a closer look see whats actually damaged, it might be to your suprise that it doesn't need so much.
      1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
