Please help water behind drivers seat - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Please help water behind drivers seat
    im in your same boat. Its not raining right now. But when it does hard no matter if im on a hill facing downwards or on a flat. Water almost every time end up behind my drivers seat. And the sencond common place it will be is infront of my seat. And that is likea 75% chance that water is there if its in the back seat. I have only had water leak in front and behind the passenger seat a couple times, and isnt as common as the driver side. And yes, under the back seat is sometimes wet as well. My seals seem fine when i wash my car and ;slight water drips only sometimes get in, and isnt a big deal. I think im gunna start with my hatch weatherstripping and see if that helps. I think it might be running front the hatch down into the seats some CUTTY way.
    • #17
      let me know if that works.i would also replace the t-top gasket before the door gasket as that is what i replaced and it didn't make a difference.
      • #18
        Any update?
        • #19
          you could close your door and sit in it, and have someone pour water and spray a hose on top of the car to at like rain. sit in there watch for leaks, feel around, take some plastic interior panels off if you have to
          • #20
            also you can adjust how your ttops sit. take off the front trim and youll find a nut and screw and washers. tinker with its alingment
            • #21
              All T-tops and sunroofs will leak a little. They are designed however to let the water run out through a channel, rather than into the car. With the T-tops off, you can see a "trough" that will channel the water to the back and down the door seal.
              What I would do is take the T-tops off, open the driver's door, and pour a cup of hot water into the trough and see where it goes. I would guess that the door seal either has a crack on the inside that it is leaking through, or that it is filled with dust and dirt not allowing it to flow well enough to drain fast enough. It should drain out through several slits along the bottom of your door.
              2000 White Firebird <br />K&N Filter, Aluminum Driveshaft<br /><br />95 White Firebird - Laid to Rest<br />K&N FIPK, Flowmaster Exhaust, Jet Chip
              • #22
                Sorry for the late response but I will try what you said thanks guys.
                • #23
                  everything ok now?
                  millionformarriage.org
                  Why stop people from getting married?
                  • #24
                    Originally posted by LD View Post
                    everything ok now?
                    No not really,thanks for asking.
                    You having the same problem?
                    I really haven't fooled with it much,I am getting ready to sell the car. I love it but I can't afford to keep it. :(
                    • #25
                      Ok, I had this same issue for about a year on my passenger side. EVERYTIME it would rain, a little, or a down pour, I would have about an inch or 2 of water. I called it my personal, portable pool.
                      I fixed this by going to Autozone and getting:
                      Weatherstrip <All the writing is in purplue> 5/16x3/4x10ft It is marked with Part# MW51634 I don't know if Autozone uses that number, or their own. No matter what, it was over with all the other weatherstripping, and silicone sealants.
                      I cut a piece that went from the center black strip, all the way to the door. Put it on kinda angled so the top would push right down on it. It stopped the leak right away! I was going to take some pictures this morning, but the camera was dead! I will charge it and take some pics.
                      I worked on this problem for like a year with using silicone. I was able to fix my drivers side with silicone, but the passenger side was being a b!#ch until I used this.
                      2000 Camaro 3.8 <a href=\"http://www.cardomain.com/ride/2040383\" target=\"_blank\">http://www.cardomain.com/ride/2040383</a>
                      • #26
                        nah, just bumping it to see what happened
                        and if it wasnt fixed maybe someone had some advice, like the post right above me :o
                        good post btw
                        • #27
                          It sounds like the water is leaking in at the back of the t-top area and running down your sail panel behind the plastic interior piece with the speaker grill in it then under the carpet.
                          With the t-top out, at the back corner, where the weather stripping meets the t-top and window, look where the weather stripping is screwed down and comes in contact with the C pillar. It sounds like the water is creeping in there and then running into your rear footwell. Squeeze some weather stripping adhesive in there and see if it doesn't fix your problem.
                          1996 Chevrolet Camaro
                          1995 Buick Park Avenue Ultra
                          --Appearance Moderator--
                          • #28
                            BUMP! Well I finally found the darn leak! Any of you guys having this same problem also check that your hood cable grommet for the firewall is all the way screwed in. I guess over the years mine became worn and backed out of the firewall and everytime it rains it has a channel of water pumping down the inside of the hood underneath the glass heading straight for it. Mine was not in at all anymore and made for a huge puddle in the back driver floorboard. Since the floorboard is unlevel and the back is further down the water would run down the little channels and fill it up first making it look like the water was coming in from the back. So glad to finally have found it!!!
                            • Manimal
                              Coil springs
                              by Manimal
                            • Manimal
                              Newby here
                              by Manimal
