miss fire? - FirebirdV6.com/CamaroV6.com Message Board
miss fire?
  • miss fire?
    when i open my throttle almost all the way open when i get into 4000 rpm i feel my car give a little a minor surge. i have no clue what it is or how to fix it. thanks in advance joe
    Re: miss fire?
    How many miles since you checked your plugs and wires?
    Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
      Re: miss fire?
      does the SES light come on or blink?
      you could always take it to autozone and ask to borrow their scanner.
        Re: miss fire?
        i changed my plugs like 2 months ago. and i am going to do my wires real soon. i was wondering if the fuel filter might be cloged? i know it needs a tune as well .
          Re: miss fire?
          I just went thru a similar sitch with my '02 (see "Spark Kutting out" thread).
          If you checked or replaced the plugs and the plug wires, the next step is to check the coil packs. There are three of them with two cylinders per pack. If one is bad, it will effect two cylinders.
          If you can tell which cylinders are misfiring (or if your garage can tell you), then switch the packs around (keep track) and see if the misfires move with the pack...then you got it. The part is less than $100 and you can easily install yourself.
          Bob
