rev limiter - FirebirdV6.com/CamaroV6.com Message Board
rev limiter
  • rev limiter
    I was wondering if my 2000 camaro 3.8, has a rev limiter. I'm to scared to try and find out myself.
    Re: rev limiter
    Yup, should be right around 6000 RPM.. if you are in park or neutral, its like 4500.. nothing to be scared about, just dont drive down the street hitting the limiter.
      Re: rev limiter
      if your an auto you have to put it in drive 1 or whatever you guys have. and shift it up fast
      WAWA-A-HOLIC
        Re: rev limiter
        Actually stock it limits you at 5800 rpm. It isnt smart to rev any higher than 6000 on stock heads or youll proly float a valve.
          Re: rev limiter
          yep you have a limiter. I think it is 5800 as well.
          6000 is not that bad on the 3.8L
