I really need to know what part to buy. I have a 94 3.4 Camaro, the air blows but it isnt cold its warm. When I put two cans of freon in the car it blew cold for about four days then it went back to warm...also when I turn the air off it "hisses" for about ten seconds..what could be the problem and how can I fix it. Please help because the south florida summer is killing me.
Need help from the A/C guru's
Re: Need help from the A/C guru's
sounds like you have a leak somewhere, get a shop (or DIY if you can) to add some dye into the freon mix and drive the car for a couple days, then you will be able to find out where it's leaking from. Also, a quick check of all valves/bolts to ensure they are on tight is also a good idea :)1995 Black Firebird Turbo 3.8L<br />Custom FS Headers | AiResearch T04B | Tial 38mm | Bosch BOV | 30\" FMIC | 2.75\" IC pipes | 3\" Exhaust w/cutout | Flowmaster 80 | Walbro In-Tank 255LPH | 180* termo | Autometer Boost + A/F (phantom) | 36# GTP injectors
You may have blown the seals in the compressor. If so, time for a new compressor :D . I have the same problem, and that's what happened to me~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by tatbackWhen I put two cans of freon in the car it blew cold for about four days then it went back to warm.Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
