Just replaced my A/C evaporator core last weekend. I had the system pressure tested and recharged. I was driving around town last night, with the A/C off, and noticed that cold air was coming out of the vents. It was as cold as when the A/C is on. It seems like the A/C is running all the time regardless if it is supposed to be or not. I cant find any loose or unconnected wires. Any suggestions on what/where to check?
A/C always on
Re: A/C always on
Originally posted by victimizati0nis the compressor running?
Re: A/C always on
The compressor is ON and the A/C lines are cold. The only way to turn off the A/C at the moment is to turn the turn the selector know to OFF. I checked all the plugs I disconnected when uninstalling the evaporator core and verfied that they were all reconnected. I am not sure what else to do. Suggestions?
I also noticed that the compressor is making a whirrr-whirrr sound. I think I forgot to add additional compressor oil when I installed the evaporator oil. I suspect that this is an unrelated issue to the A/C not turning off all together.Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
Re: A/C always on
There are only 3 positions on the enviroment control switch that the compressor will not be commanded to operate. They are:
1) OFF
2) floor
3) vents
For all other positions
1) A/C MAX
2) A/C
3) A/C bi-level
4) Defrost
5) Defrost bi-level
the compressor will operate.
Did you check to see if the compressor operates on the Floor and Vents setting?
Also, on my car ('99 FB) the compressor clutch is controlled by the PCM via a pressure sensor found installed on the high pressure refridgerant line just before the evaporator. The older systems used just a pressure switch in that location that directly controlled the clutch. Either way If I were you, this is where I would start looking.
If you changed the evaporator core, how did you re-charge the refridgerant? Did you use proper gauges? Improper pressures can cause the system to operate erratically.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
Re: A/C always on
I just must be an idiot. I have always driven around with the vent setting on defrost bi-level. That is where I had it the other day when I became concerned. On the drive to work today I turned it to floor and vent only settings. Sure enough the compressor turned off. I am slightl please that the original compressor is still going after 10 years/125,000 miles of constant usage. I probably keep the vent on floor or vent from now on so the compressor is not running constantly.
As far as re-charging the refridgerant... I took the car to a local A/C shop and had it professionally tested and recharged. Cost about $100 to test/recharge and $30 to strictly test.
Thanks for the help!Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
Re: A/C always on
Originally posted by D_FisherI took the car to a local A/C shop and had it professionally tested and recharged. Cost about $100 to test/recharge and $30 to strictly test.
i recharged my car myself for $30 (acually i did 2 cars)
