Ok, I have been having an issue with my 95 3.4.
When I stomp on the gas or accelerate fast the car doesn't want to shift. If I let off the gas slightly it shifts, then I can repress on the gas to begin accelerating again. If I don't let off the gas it just revs higher and higher accelerating slowly.
At any rate I have had this obnoxious rattle in my exhaust as well. I believe the rattle is comming from the inside of the CAT. Yeah I am sure it's not the heat shield, and I believe the rattle is getting worse. I don't know if the rattle is related to the above problem or not, however tonight my car finally kicked up an SES light.
Now my question is how do I retrieve the darn code. It is a 16 pin connector, and my haynes manual only shows me how to jump a 12 pin connector. Can I jump the terminal on a 95 3.4 or does it have to go in?
___________
| | | | |A|B|
------------- 6 Pin Connector
Haynes says to jump A and B
_____________
--------------- Mine is a 16 Pin
(No The A and B Do Not Work) ;)
Thanks for any help, and if you have any ideas as to what the shifting problem is please feel free to let me in on the secret. [img]smile.gif[/img]
-JinX
___________
| | | | |A|B|
_____________
-JinX
