Mystery Leak - FirebirdV6.com/CamaroV6.com Message Board
Mystery Leak
  • Mystery Leak
    My passenger rear floor board is SOAKED with water. It's been raining quite a bit here in Tampa Bay, and my car has been outside for most of it. I can NOT find this leak anywhere. NO WHERE else in the car is wet. Any suggestions?
    http://www.cardomain.com/ride/2287597
    :( SOLD! NO LONGER A CAMARO OWNER :(
    Re: Mystery Leak
    I have the same problem. I think it's coming in from my weatherstripping somehow. Anyways, it'll come in, then go down the grey peice of plastic on the inside top, and drip onto the carpet in the back. I'm not entirely sure where it enters the car at or how.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
      Re: Mystery Leak
      next time it rains get in your car and see where its coming from thats what I did but still haven't solved the problem yet because of time
        Re: Mystery Leak
        i saw on another forum, someone was acually having water come in through the grommet that goes through the firewall. That is probably where water is leaking in
          Re: Mystery Leak
          where is that?
            Re: Mystery Leak
            Unless I misunderstood him, I think he means behind the passenger seat. I doubt it came through the firewall and went all the way to the back of the car without showing itself anywhere else. I've sat in my car while it happened, and it's leaking around the door somewhere, and dripping off the plastic peice up top for me.
            ~97 3.8L V6 Camaro~
            A few things
              Re: Mystery Leak
              I have the same problem, and I thought it had somthing to do with my amp wire, but I guess I should look elsewhere then.
                Re: Mystery Leak
                I think mine might be related to the amp wire too... I have run through the door, and then under that gray plastic all the way to the back. i wonder if water is coming in from where i have my amp wire running? but then wouldn't my front passenger get wet too?
                  Re: Mystery Leak
                  My passenger side footwell is soaked during heavy rains too, I believe it under the passenger side dash from a grommet, I can't quite find the leak.
                    Re: Mystery Leak
                    yes, that is where it is comming from, just like i said earlier
                    i saw the SAME exact problem elsewhere
                      Re: Mystery Leak
                      My T-tops leak like a son-of-a-*****. Replaced weather stripping and everything, didn't do anything.
                        Re: Mystery Leak
                        Thought about doing that, but for 170 bux from gmpartsdirect, for a non guaranteed fix... i dunno 'bout that.
                          Re: Mystery Leak
                          i had that leak it was my plug cause we never put it back in after fixing nitrous wires.
                          WAWA-A-HOLIC
                            Re: Mystery Leak
                            where is this "plug"?
                              Re: Mystery Leak
                              is the back of your back seat getting wet too?
                              maybe its coming in from the hatch.
                              <a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
