anyone herd of splitfire and e3 sparkplugs? - FirebirdV6.com/CamaroV6.com Message Board
  • anyone herd of splitfire and e3 sparkplugs?
    i know almost everybody here uses nkg spark plugs just wonder has anyone herd of eitehr of these brands. saw them in summitt and they looked good.
    JpX
    Re: anyone herd of splitfire and e3 sparkplugs?
    My advice dont use any spark plug with more that two tips because alot of times the spark will split between more then one tip and that makes it a weak (not as hot) spark. For example platinum fours suck!!! I usually go with ACDelco personally. But i have heard some good things about the splitfires.
      I have probably used every major sparkplug(including splitfires) in the last 8 years.
      I notice near 0 difference. Only thing I ever saw was maybe a little longer life, and even that was so miniscule it woudln't affect my purchasing.
      This coming from a interanally stock guy with some bolt ons. Between a 2.8L, 4.3L, 3.4L, and a 3.8L and in a way bewteen a 2.4L DOHC and 2.2L cavaliers.
      Just imo....
      right now I have been using Autolite 605s based on L36 grand prix reccomendations.
      Cheap and seem to work fine. but my last set started giving me misfires after 12k but I was fiddling with timing and fueling a little that I might have prematurely killed them.
        i have herd splitfire are good and they are bad too but if you get theregular one it comes with a 3 year warrenty and the platnium come wit ha 100k mile guarantee. e3 comes wit ha 5 year 100k mile warrenty. look in summit about them.
        JpX
          This is a BS statement and has no basis in science. There will only be one spark, to the path of least resistance. I'd say that in general the spark will even follow the same path every time unless plug wear or fouling change which tip corner has the least resistance.
          Splitfire got sued by gov big time over their claim on a split spark which is why they're careful not to ever say they it will split the spark. In fact they ended up changing their box and advertising, which presently only shows a single spark firing.
          2001 Pewter Firebird Y87, M5
          Go Sabres!
