weird f-body question - FirebirdV6.com/CamaroV6.com Message Board
  • weird f-body question
    i have a question that have been bothering me for a while.... how does the door ajar works on 98+ camaros? what i mean is that, lets say the the car is shut off but the key is in the ignition . so, if driver door is open, it makes beeping noise .....where is button that door pushes against the body panel... i was just looking for it.... i couldn't find any... i remember in my 96 camaro, there was a spring type plastic thing toward the front fender and as soon as it pressed (by door) the beeping stops ..... there's nothing i could find on my camaro (98 model) ..... is there some kind of infrared sensor? .... :curious:
    09 Nissan 370Z MB M6 Sports Package
    www.the370z.com
    Re: weird f-body question
    definately not an infrared sensor, that would be cool though
    I think its probably just a - and a + that makes contact
      i couldn't find anything like that ..... actually all there is just a piece of rubber with two holes in it ...... thats why i guess it's "infrared" but i need to know ....
      www.the370z.com
        it is a little button you press down.
        its somewhere where the door mounts are
          infrared makes it possible to view body heat, not closed camaro doors.
            I had the guy at a car stereo place disable it. He was able to disable it
            in a panel on the passenger side....it took him 20 minutes.
            Thank God he did the buzzing was driving me nuts.
            Phil
              <a href=\"http://photobucket.com/albums/a371/boyoi/firebird/?sc=1\" target=\"_blank\">My FireBird</a> K&N intake,Gutted cat, glass pack muffler.........Lots more to come...... <br />Getting my exhaust soon :)Rumbler Exhaust w/ Hooker\'s Headers :)
                Infrared is used for many things, including distance measurement and object sensing. Sensing body heat is just one of many applications for the technology. ;)
                1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
                  so ..... , no one has a clue how the door ajar is activated..... huh... c'mon guys someone knows the answer......i can't rest until i get the answer... i have weird personality....
                  www.the370z.com
                    i already gave you the answer
                      For 93 - 97 f-body yeah there is a button by the door hinge.... i clearly remember it on my 96 but in my new one i don't see anything.... i even put my hand around and up-down from the hinge ....nothing....
                      i did noticed even my door is open slightly i get ajar, that means it's somewhere on the locking side( handle side) of the door ... what'cha think?
                      www.the370z.com
                        On my friend's grand cherokee, it was built into the latch for the door on the body side.
                          it's probly set up like the fords are in the lock plate in the door there is a switch that when the door closes makes contact and shuts the circuit .
                            do all camaros have the door agar light? unless mine burnt out, i dont seem to have it.
                            When you open the door, if you look at the latch, and can open/close it, that is where the switch is
                              no they dont. i dont have one either... which is really weird. i've never seen a car w/o a door ajar light until i had this car.
