The guys over at valvolone are telling me to change my fuel filter and my differential fluid. My car has about 62k on it and i havent changed either but i bought the car with 50k on it. If i assume that the previous never did either should i perform these changes?? Thank you.
maintenance Q
straight to the point i like that. i will do these then i was just unsure about the differential fluid because i am unfamiliar with that.2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
The general rule is like fuel filter every 15K and diff fluid around every 30K-40K.Matt
1998 Mystic Teal Camaro M5
I usually do the diff fluid every 10k, but I'm kind of crazy on that after doing my lsd swap myself - I just like to get in there and look around to make sure everything is still as it should be.
Also don't ignore your tranny fluid. I usually have mine changed 1/yr unless it starts indicating it wants it done before that.
Fuel filter changing = longer engine life due to less crud getting into it through the gasoline.-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...13 hours ago
