maintenance Q - FirebirdV6.com/CamaroV6.com Message Board
maintenance Q
  • maintenance Q
    The guys over at valvolone are telling me to change my fuel filter and my differential fluid. My car has about 62k on it and i havent changed either but i bought the car with 50k on it. If i assume that the previous never did either should i perform these changes?? Thank you.
    2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
    Yes.
    Matt
    1998 Mystic Teal Camaro M5
      straight to the point i like that. i will do these then i was just unsure about the differential fluid because i am unfamiliar with that.
        The general rule is like fuel filter every 15K and diff fluid around every 30K-40K.
        Matt
          i appreciate the quick responses. thanks for the helpful info
            Change a few other things in the process..Air filter,PCV Valve...
              I usually do the diff fluid every 10k, but I'm kind of crazy on that after doing my lsd swap myself - I just like to get in there and look around to make sure everything is still as it should be.
              Also don't ignore your tranny fluid. I usually have mine changed 1/yr unless it starts indicating it wants it done before that.
              Fuel filter changing = longer engine life due to less crud getting into it through the gasoline.
              -Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
                Whenever buying a used car, (hopefully, it's not used up) I generally do all maintenance on it within one year, always assuming the previous owner did nothing. Too many people ignore thier cars exept for the gas tank.
                  Run a bottle of fuel system cleaner.
                  • 187shark
                    by 187shark
