Whats the cheapest way to make my camaro faster? - FirebirdV6.com/CamaroV6.com Message Board
  • Whats the cheapest way to make my camaro faster?
    I just received 1500 dollars for fixing a 2003 Harley Roadster and selling it. The job took around 3 weeks to paint it and replace some parts. Anyway, I just want to know what would be the best part or parts to buy to make me faster other than nitrous. Should I get cams if I can, or a new rear end? I already have the basics, ram air, k&n, and exhaust. I want to be able to tie 99 mustang gt's, and not just the older 4.6's and 5.0's. Some body help me out.
    Re: Whats the cheapest way to make my camaro faster?
    get some ignition upgrades, wires, plugs, coils to start out with. an MSD DIS 4 box will help with that too. Unless you deicde to do the cam yourself it is gonna cost a lot, if you dont want to get into the cam, get rockers instead, very easy upgrade, and good for 20 hp for 1.9 Ratio. Also a cam may require new springs, retainer etc.... tires are also key, you will need to grip the road in order to take down anything, are you A4 or M5?
      I would do the following
      *Roller Rockers 1.9
      *MSD DIS-4 , MSD coil packs , Wires , NGK plugs
      *maybe put some bigger injectors in it
      *LSD (3.43's)
      *Aluminum Driveshaft
      *Spec stage 2 clutch (3 if your planning on going T/C , S/C , or nitrous later on)
        Im a M5.
          2K's list looks perfect for the starting off mods, I'd go off his.
            Would it be better to get 3.73's?
              it would be for performance , but your gas mileage will get >>>>>>:spank:
                skip the ignition junk, not gonna gain much from that. I would get in on the abbotts racing cam group purchase they are doing right now. Make some really good power with their NA cam.
                http://www.bowtiev6.com/
                  Whats the website?
                    http://www.fullthrottlev6.com/forums...ad.php?t=19135
                      a good price yes, but are you able to do your own cam swap? If not add another $400-700
                        Where would you get some Roller Rockers? I've had trouble finding them.
                          zzperformance.com
                          Custom interior...
                          TEAM NoVa
