Hi i've been having a problem with my 94 firebird 3.4. When i start it some times the low oil light comes on, so i checked the oil dipstick and it says its full. also my oil pressure is really high at like 75-80 psi when driving or when i idle. I searched both these problems on this forum. I believe the i have a bad low oil sensor and a bad oil pump pressure bypass value. I just wanted to know if any of you come to the same conclusion.
3 days ago
