Rear End? - FirebirdV6.com/CamaroV6.com Message Board
Rear End?
  • Rear End?
    With the $1500 dollars I have I think that Im going to buy a rear end and a clutch. But im not sure what I should be looking for as far as the rear end. Can I buy a rear end out of a Z28? Ive been told I can but as far as the ABS and Traction control which I dont have. Will it still bolt on? By the way my car has 77000 miles on it will that affect anything? And as far as a clutch what are some ones that I should look at? I need help!
    Re: Rear End?
    if you are putting out any sort of power i would go with this baby http://store.jandjspeedshop.com/prod...products_id=30 so just save a little longer. clutch, i would go centerforce i believe, the SPEC ones
      Re: Rear End?
      Jesus $1500?
      fwiw
      I have bought 3 clutches and 2 rear ends for less then $1500 total. And one of those clutches was a spec II.
      IMO, if you have a v6, don't ever waste your time on a 12-bolt. Just go through 1-2 10=bolts before you start going after a 12-bolt with a v6.
