post fuel pump install question - FirebirdV6.com/CamaroV6.com Message Board
  • post fuel pump install question
    ok, so i installed the Walbro last nite via the trap door.
    I hooked a pressure gauge up to see if my problem of losing pressure while the being off was fixed and this is what i found:
    After 4 hours, pressure drops from 42psi to 27psi
    After 8 hours (when I woke up this morning to go to work) my pressure was at 0psi.
    before the install, with the stock pump, my pressure would drop to zero within seconds.
    Any ideas of why its still dropping? is that normal??
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    Re: post fuel pump install question
    i'm pretty sure thats normal, i would say 4 hours to drop to 27 is pretty good, why do you think the pump primes itself when you turn the key before you start the car
      Are you still have long crank times with the new fuel pump installed, keep this thread updated please im having similiar problems myself with my 3800.
      Thanks
      ---Niño---<br /><i>95\' silver 5 spd</i>
        ditto , sometimes my car cranks right up and sometimes it takes like 10 mins to get it started..... retarded and embarrising ........ and this trap door...... what is this u speak of? u dont need to explain if u know the link to a site or thread ..... thanks
          I'ts just a door in the back of the trunk that gives you access to the pump. Instead of dropping the tank and all that work. ;)
          Red 1998 Camaro<br />Mods so far=<br />K&N
