Got an oil leak and I don't know exactly where it's coming from... - FirebirdV6.com/CamaroV6.com Message Board
  • Got an oil leak and I don't know exactly where it's coming from...
    As the title says, oil leak from who knows where. It's dripping down the oil pan onto the y-pipe and then the driveway which I have had to clean like 100 times now because of this. Anyone have an idea where it may be coming from or is my description to vague?
    \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
    Rear main seal. (Which means you drive your car too hard) ;) I have the same problem.
    1993 Pontiac Firebird 3.4L V6 A4<br />F41 RPO suspension option<br />119K miles<br />Fastchip<br />K&N \"Filtercharged\"<br />Airbox cuttout CAI<br />ASP underdrive pulleys<br />Pacesetter Headers<br />Flowmaster 80 Series 2.75 cat-back<br />MangaFlow Hi-Flow Cat<br />Corvette Servo<br />16.4 @ 81 MPH
      ...sounds expensive... am i wrong?
        few hundred
            that was the f word incase you all were wondering...
              I was guessing SH*T
                Yup... sounds like your main seal. Mine went out on my 3.4L and it leaked into my tranny... Not good... but also, I was missing my tranny mount b/c the people who did my clutch job forgot to put it back on... YEA!!! but the rear main will run you a couple hundred easily.
                \'97 Camaro 3.8L
                  anyone try the no leak stuff?
                    I looked at it again today and I think it may just be the oil pan gasket. What do yall think of the chances of that. I just think that after just 65k miles the rear main seal going out is kinda too early. Can't really see above where the oil pan gasket is so I can't tell if it's coming from above it or not.
                      dude, check ur oil pressure sending unit, mine was loose, and i couldnt find out where it was coming from, sure enough it was it.
                      96 camaro Y87~3.8 5 speed~75 shot zex nitrous~K&N~80\'s series flowmaster~yokahama tires~323 gears~5% tint all windows~bose sound~http://www.cardomain.com/ride/822994
                        make sure its not ur oil pan plug. make sure it has a rubber o ring on it. idiots are Chevy sold me one w/out it, i forgot it needed one, i thought i had a rear main seal leak at 60k. i wanted to kill them.
                        99 WS6
                        13.25@104.97 - Lid + soon to be more other stock items ;D
                        Originally posted by camaroextra
                        tears are great lube, but its hard to get a girl to cry onto her own ***.
                          it's not the plug, it's coming from above the plug, I can't see above where the oil pan gasket goes so I can't tell if it's coming from there or above it. I also looked in my haynes manual about the sending unit and it said to get to it you take off the oil filter and the ac compressor or whatever and that's on the front of the motor and the leak is coming from the back.
                            that stuff is worthless :rolleyes:
                              remember if you do the rear main seal do the cover gasket too, thats usually the problem.. you have to drop the tranny for the rear main.. you have to drop the suspension for the oil pan gasket, i'd rather drop the tranny though
                              Mystic Teal Metallic
                              ET:15.1 NA 14.3@96 MPH 75 Dry Shot
