ticking noise - FirebirdV6.com/CamaroV6.com Message Board
ticking noise
  • ticking noise
    lately just recently i have been hearing a ticking noise from under the coil packs it gets louder as i accelerate but i have no clue wat it could be ...sticky lifters idk ? and also the cars rpm jumps around at idle like from 900-1100 back and forth maybe once every other start but stays like this for a while.... ive done a complete tune up theres nothing i left out!
    Re: ticking noise
    sounds like a lifter/pushrod.
    not much you can do without taking the valve cover off and checking
      Re: ticking noise
      ??? yeah you can... a sticky valve is gonna show up in a vacuum test, and if you wanna tell where the ticking is coming from, take a piece of hose, hold one end to your ear and the other to a valve cover. its like a stethescope but cheaper and just as good. you'll be able to hear exactly where the sound is coming from.
        Re: ticking noise
        so he can fix it with the valve cover still on?
