past few days....at random my ABS INOP light will come on and stay on till i turn the car off then back on...then the light goes out...then eventually light will come back on....anybody had this problem? whats up?
ABS INOP Light
ABS INOP Light
30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>Tags: None
Re: ABS INOP Light
The relay points my be going bad and not making good connections, replace the relay, see what happens.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Re: ABS INOP Light
relay? sounds like a shot in the dark to me.
have the code read
Re: ABS INOP Light
i just know if i pull my relay out, the lights come on.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Re: ABS INOP Light
No burnouts....owned my car for 5 years only done 2 of those..dont like to spin tires spinning=loss of time.....where would this shot in the dark relay be located??30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
Re: ABS INOP Light
Pull the wheels sensors and clean them off, especailly the rear one, might have a build up of metal shavings and getting false readins.
Also any chance you have mismatched wheel sizes(like vette wheels? )-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Re: ABS INOP Light
Originally posted by BobbyZ72i just know if i pull my relay out, the lights come on.
:stp:
Re: ABS INOP Light
I think you will need to hit up a mechanic or the dealer to get the ABS computer codes pulled. Pretty sure parts stores don't have anything to view those.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Re: ABS INOP Light
Originally posted by shenanigansPull the wheels sensors and clean them off, especailly the rear one, might have a build up of metal shavings and getting false readins.
Also any chance you have mismatched wheel sizes(like vette wheels? )30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
Re: ABS INOP Light
Originally posted by vanbibberdid you check the third break light?30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
Re: ABS INOP Light
because if the third break light has a short,burnt bulb or a bad connection it will set the abs inop light for some reason. ive had it happen probably 10 times on my fbods.
Follow me!
Or this
Re: ABS INOP Light
Originally posted by vanbibberbecause if the third break light has a short,burnt bulb or a bad connection it will set the abs inop light for some reason. ive had it happen probably 10 times on my fbods.Last edited by 1SL1k30thCam; 07-06-2006, 10:06 PM.30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
