Out of the garage with more problems.... - FirebirdV6.com/CamaroV6.com Message Board
  • Out of the garage with more problems....
    So my parents picked up my car while i was at work from the garage, they replaced my Sending unit for my gas tank - now i'm finaly getting a reading...
    however, after work, i opened my door, notice, no dome light, i'm like alright, i guess it just burnt out (even though it didn't look burnt) I turn on my car, Radio (JVC) doesn't turn on! I'm like oh, must be fuse then, changed the fuse....still no go. So to be on the safe side, I changed every single fuse in the car. And still the dome light nore the Radio will turn on. Everything else works inside and outside of the car (gauge,power windows,flashers,horn).
    I dont see how this couldn't happened changing the sending unit from the gas tank,
    we went through the trunk to replace the sending unit(cut a hole) , they did a great job, doesn't even show and saved me +500$ on labor, but what the hell could cause my radio and dome light not to work anymore?!?! Any suggestions!?
    1986 Firebird - Sold<br />1987 Trans am - sold<br />1994 Firebird - Current.
    Re: Out of the garage with more problems....
    did u check the fuse behind the radio sometimes head units have fuses behind them
      Didn't check that, it's just I dont see how this could happened when they only worked from the trunk area of the car, is there any wires or some sort of relay, harness, whatever on the side somewhere?
        Do you have door chimes?
        1998 Camaro V6 \"Black Mamba\"<br />Y87<br />Whisper Lid w/ K&N filter<br />Flowmaster American Thunder<br />Numerous appearance mods.<br /> <a href=\"http://www.cardomain.com/ride/2154172\" target=\"_blank\">Car Domain</a>
          no because I took off the little thing that made noise because it wouldn't turn off when the key was in the ingition (I think) i dunno, i did that like 4months ago..
            i would be willing to bet your BCM went out, if you were having chime problems, then that was probably a forewarning that your bcm was starting to give way, i would check that out
              What is a BCM..... ?
              sorry
              <-- noob
