Oil drain bolt - FirebirdV6.com/CamaroV6.com Message Board
Oil drain bolt
  • Oil drain bolt
    Why didnt the oil drain bolts come with a magnet on it?
    Or anywhere in there...
    Regardless, I'm about to weld a magnet onto the bolt tip
    Re: Oil drain bolt
    you know, you could probably buy one with it ;)
    2000 3.8 A4 Pewter Camaro
      Re: Oil drain bolt
      too late, already self-fabricated my own design
      Now I need one for the rear
      and one for the cooling system! lol J/k!
        Re: Oil drain bolt
        the rear diff cover should already have magnets in it as well as the tranny. some pans do have magnets but i don't know if ours do. I'm pretty sure my drain plug is magnetic anyways :)
          Re: Oil drain bolt
          my 98's is
            Re: Oil drain bolt
            mine wasnt :(
              Re: Oil drain bolt
              you dont need to weld it, just magnitise it
                Re: Oil drain bolt
                yea i just epoxyed it
                  Re: Oil drain bolt
                  lol, why?
                  you could of just magnitised it, would of been a whole lot easier
                    Re: Oil drain bolt
                    You can buy the magnet bolt at any auto parts, around here atleast you can. Mine always has stuff on it when i change my oil..about every 3k. where did you epoxy the magnet at? on the tip of the bolt, or on the out side of the bolt? either way would work i guess.
                      Re: Oil drain bolt
                      How do you do that?
                      Justin<br /><a href=\"http://www.bass482.com/firebird/index.html\" target=\"_blank\"> 2000 Black Firebird A4 Y87<br /></a>170.2rwhp/203rwtq (SAE Corrected)
                        Re: Oil drain bolt
                        he means: the magnet already comes magnatized. You just stick the magnet up to a piece of metal and voila.
                        think mcfly think ;) sorry just kidding, couldnt resist
                          Re: Oil drain bolt
                          the tip
