Steering Wheel Cover Removal - FirebirdV6.com/CamaroV6.com Message Board
  • Steering Wheel Cover Removal
    Anyone here ever remove the front cover on the steering wheel?
    I need to do this to fix/replace the horn button.
    I sooo get the vibe that as soon as i get started that the air bag will go off and take my head off.
    [img]graemlins/stickpoke.gif[/img]
    Let's hear some advise experts.....
    I dont wanna die to fix my horn ....lol any help is appreciated.
      Thanks everyone.... i just took half my face off when the air bag exploded into my face. ugggh
      LOL
      Still haven't started yet..... googgled my *** off yesterday to find a proper "how to"
      Nadda
      Surely at least one of our 6000+ members has done this by now...... get in this thread a give me the 411. ....please.........
      Friends dont let friends kill themself with airbags....
        i am not sure about this but I thought the air bags went off with a senser when you get hit? i dont think it would go off, but i dont really know
        <a href=\"http://www.cardomain.com/ride/802975/3\" target=\"_blank\">http://www.cardomain.com/ride/802975/3</a>
          Head on over to LS1tech and do a search, plenty of people over there have done it. From what I understand, you just need to take out the bolts in the back of the steering wheel. I would unhook the battery just to be sure.
          2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
            I'd unhook the battery and pull the air bag fuses. Carry the steering wheel upside down once removed too.
              Actually, the proper handling of the airbag is with the cover away from you while carrying, and facing upwards when set down on a bench or table.
              All you have to do is disconnect the battery, unhook the airbag fuse and then handle the airbag with care. The airbag itself activates with electricity so handle with caution. I'm not sure how sensitive the bag is but they even caution against static electricity. Just some info.
                Thanks for the replys..... off to ls1tech to see what ppl over there have to say.
                  I've done it!
                  Just pull the Air bag fuse.
                  Then, loosen the two torx screws that hold the Airbag to the wheel (From behind).
                  Et Voila!
                  96 Teal Firebird<br />Colchester, Essex, UK<br /><a href=\"http://www.centrestage.free-online.co.uk\" target=\"_blank\">www.centrestage.free-online.co.uk</a>
                    when i was in school we took an air bag. We went to an empty parking lot (with my professors) and layed the air bag deployment side down and put a butchers block ontop of it. We ran a looooooooooooong peice of wire to a remote power source and it only took .4 volts to pop and it sent the butchers block over the telephone pole it was near. I would disconnect the battery, pull the fuse and let it sit for a while, there tends to be capacitors in that system that may take a few minutes to drain completely. Then go at it.
                    1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
                      Battery...
                      Fuses....
                      Wait to make sure...
                      Well I guess that should cover it. If i dont get killed i'll buy you guys a beer.
