under pulley belt - FirebirdV6.com/CamaroV6.com Message Board
under pulley belt
  • under pulley belt
    if i get the water underpulley and the Alternator under pulley how much longer of a belt do i need and what is the numder of the belt?
    Re: under pulley belt
    i've got the water pump and I didnt have to change belt lengths
      I ask about water pump and Alternator pully
        I know a guy with one, i dont know which, but i do know he said hes using the same belt.
          Yea the same belt. On zzperformance website it says if you use both the water pump underdrive pulley and an alternator UD pulley you need a larger .
            Does anyone know I would realy like to know
              http://www.zzperformance.com/grand_p...ts1.php?id=341
              i assume that number 923 will work. email the zzp folks and they should have an answer for you. 92.8 inches it claims btw.
              Visit My F-Body Page
