loss in power greatly - FirebirdV6.com/CamaroV6.com Message Board
  • loss in power greatly
    i recently cut the airbox like a cheap idiot for the free ram air...and now wen i give it gas it takes a lil bit to get up to speed like it lost compression what is the leading cause in lost compression!!!???? must know
    Re: loss in power greatly
    do you have a compression tester? They're only lik $8-$18.
    I wouldnt be making assumptions. It makes an azz out of u and me.
    Your compression could be fine.
    lost compression can be:
    bad headgasket
    bad valves
    cracked block/ cracked heads
    or in my situation: bad piston rings and bent connecting rod
    I love compression testers, I REALLY wish I had a leak down tester
    Youre not a cheap idiot. I've done MANY free/cheap mods to my car some were half-azz
    some were Great! Trial and error is part of the learning experience.
      did u wash out the lid after ya did it and let it dry to get the dust offa it? did u reconnect the IAT sensor? look to see if something is blocking the intake. i highly doubt you lost compression. if you did its coincidental. cutting your box wont do that unless you sucked some crap into the motor...
      2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
        idk wat it is but the engine bay when running is sooo loud when i give it gas i wish someone could hear it like it sounds really loud and it ticks sometimes ....so idk what it could be i know im loosing power from something and im thinkin its compression related because i did the free ram air mod a whileeee back but ever since its never had its power..i dont know who to bring it to to get it checked out ... i live in PA is there any people who specialize in our cars?
          free ram air mod has nothing to do with compression
          what are you talking about?
            loud? as in higher rpm? u sure u didnt mess up a vacuum hose? it will make it run hotter and louder and definatly bog it down
            • 187shark
              by 187shark
