Bulb Part Numbers (PewterBird)
These Part#'s are from a 99, But should be the same throughout the years.
____Exerior Lamp Usage____
Back-up Lamp-----------------------------3155
Back-up Lamp (Export)--------------------P21W
Fog Lamp (Chevrolet)---------------------894X
Fog Lamp (Export)------------------------H3
Fog Lamp (Pontiac)-----------------------880
Front Side Marker Lamp-------------------194
Headlamp Low Beam (Chevrolet)------------9006
Headlamp High Beam (Chevrolet)-----------9005
Headlamp Low Beam (Pontiac)--------------H4703
Headlamp High Beam (Pontiac)-------------H4701
High-Mount Stoplamp (Chevrolet Export)---W16W
High-Mount Stoplamp
(Chevrolet and Pontiac Domestic)---------921
License Lamp-----------------------------194
License Lamp (Export-Europe)-------------W3W
Park and Turn Signal (Chevrolet)---------3157k
Park and Turn Signal (Pontiac)-----------3157NAK
Park and Turn Signal (Export)------------P27/7WLL
Rear Fog Lamp (Export)-------------------P21W
Rear Sidemarker Lamp---------------------194
Side Repeater Lamp (Export)--------------W5W
Taillamp, Stop/Tail----------------------3057
Taillamp, Stop/Tail (Export)-------------P21/W5
Tailamp, Stop, Turn Signal (Pontiac)-----3057
Taillamp, Turn Signal (Chevrolet)--------3057
Taillamp, Turn Signal (Export)-----------P21/W5
Tailamp (Fill In)------------------------194
Taillamp (Fill in) (Export)--------------W5W
____Interior Lamp Usage____
Ashtray Lamp-----------------------------194
Automatic Transmission Indicator Lamp----73
Dome Lamp--------------------------------906
Front Side Door Courtesy Lamp------------74
Heater and Air Conditioning Control Lamp-37
Instrument Cluster Lamp------------------161
Instrument Panel Compartment Lamp--------194
Reading Lamp-----------------------------212-2
Reading Lamp (most 2001+up)--------------194
Rear Compartment Lamp (Convertible)------562
Rear Courtesy Lamp (Convertible)---------562
Turn Signal Indicator Lamp---------------161
Warning/Indicator (Chevrolet)------------161
Warning/Indicator (Excluding Turn Signal Indicator) (Pontiac)------PC74
4 days ago
