hey i was wondering if anyone had the same problem after driving hard on it theres smoke comin from the engine smells like coolant burning but im not overheating n i jus replace the water pump n there no crackd hoses i checked all of them dont kno where its coming from can anyone lead me in the right direction so i know whats causing this problem
smoke coming from engine after driving hard
Re: smoke coming from engine after driving hard
probably oil dripping on the exhaust manifolds2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
not sure, but head gasket? an oil and coolant mix burning could explain both the smell and the smoke. Coolant burning would be more of a steam than a smoke, but will have a very distinct odor, but the oil would cause smoke. Any drops on the pavement under the car at all? Maybe try a cylinder compression check, could indicate a head gasket leak. The compression should be minimum 100 psi. If low on one cylinder, or two adjacent cylinders on all strokes with no increase usually indicates a blown head gasket.
Also make sure it's smoke, not steam. If it's just steam, check for coolant leaks EVERYWHERE they can come from any of the several connections, not just the engine. It happens to my van whenever it idles for an extended period of time... turned out to be a very small hole in the radiator, that doesn't leak coolant, only leaks when enough pressure builds up and it releases steam.Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
My EGR gasket blew out on mine and threw oil onto the valve cover which caused it to smoke ...burning off the oil on the hot engine....it eventually sealed it's self back up, but I replaced the gasket tonight since I was performing other fixes to the car.
actually its steam not smoke my bad ..... and when i checked where its coming the steam is coming from the left side ...well if ur standing in front of the car its the left side but cant find where thou
Originally posted by CAMARODJDactually its steam not smoke my bad ..... and when i checked where its coming the steam is coming from the left side ...well if ur standing in front of the car its the left side but cant find where thou2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Oil usually only burns blue when mixed with exhaust gases, and it wouldn't smell like coolant... I agree with slow6 check heater core hoses. Have you ever noticed any steam on the inside of the car, or windows fog up with heat on or anything? if so could be the heater core itself. Try to check for the leak while it's leaking if possible, I know you said it didn't do it all the time.
What I did on my van... I taped white paper towels around the area that I suspected was leaking (not reccomended touching the engine block... a little too hot for the adhesive) and then left it there for my daily commute and then once stopped I took off the tape and there it was... orange on the towel to confirm it. Just make sure not to obstruct anything when taping...Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
i turned on the car n i revved the the motor a lil bit n u seen the cooolant being squirted out of the hose thats runs from the heater core to the engine so i hurried n shut the car off ..tried to go to the local auto parts store n they didnt have it in stock or have it in there system weird huh so i had no choice but to go to the dealership n order the hose 165.00 for the hose its the one thats half rubber n half metal now just waiting for the part to come in ,its suppose to b in tomorrow hopefully so now the car is in the garage
