A/C shuts off when Accelerating - FirebirdV6.com/CamaroV6.com Message Board
  • A/C shuts off when Accelerating
    Have a 99 camaro 3.8 5 speed, when i get on the gas to pass anyone or something.. my top a/c vents shut off untill i resume back to normal speed... is this a vacumm problem??
    Re: A/C shuts off when Accelerating
    It's designed to do that, so it's normal.
      it is programmed into the computer to do that, your car is normal
      http://www.bowtiev6.com/
        ^^As they said. If you nail the gas, the computer turns off the A/C to deliver more power to the wheels; then as you let off the gas, the A/C will continue.
          Your all wrong ! The AC vents do not shut off at WOT, the compressor does and its something you wouldnt even notice. Im not sure what would be turning your AC vent fan off.
            hmmm....that is funny cuz I clearly have a spot in my hp tuners to change when it turns off and activates again when accelerating :shrug:
              Yes it shuts the AC compressor off not the vent fan motor.
                but you still don't get that nice cool air coming in for a sec on or a minute depending on how slow the stang is.... haha
                  man, that makes some sense now. i've noticed that on my car and i was trying to figure that out. good to know.
                  Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
                    Uhh I don't know about you but I definitely notice when the compressor gets shut off and I get outside temp air. Especially on those days where the temp hits 100+.
                    But yeah, normal behaviour. Mainly so the high RPMs don't break the compressor, but also to give you more power.
                    And by experience I will tell you that this is a great feature ;) I have had the repair bill for replacement before, it's not pretty. Not in an fbody though.
                    2000 M5 Pewter Firebird [Monsoon stereo]<br /><a href=\"http://www.centerlinewheels.com/sub_wheel.php?mw_id=2\" target=\"_blank\">16\" Centerline Galaxy Wheels</a> . <a href=\"http://www.bfranker.badz28.com/headlightfix/\" target=\"_blank\">Headlight fix</a> . Under dash lighting . Dashmat . Headlight conversion<br />84k miles<br /><br /><a href=\"http://www.cardomain.com/id/tucsonbird\" target=\"_blank\">Cardomain</a><br />Tucson, AZ
                      yeah, its normal. don't ever let a ricer tell you that you beat him because he left the AC on by mistake. I have even rat at the track with it on and lost .1 on the run. that can be explain by the split second before the compressor disengages.
                      95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
                        no, the reason is because the ac compressor cant handle the high RPM's of the engine
                          no, what he said was correct.
                          2000 3.8 A4 Pewter Camaro
                            no, the ac compressor cannot handle high rpm's, and it shuts off for that reason.
                            or, it does in EVERY other car, maby not 4th gen fbodies then.
                              ok im new here so im not going to get into the whos right and wrong but i know my dads truck (98 ram 1500) was doing the exact same thing with the AC, and it turned out it was a vacume leak. dunno if it helps but i needed to get my first post somewhere!
                              O btw since im new: 99 camaro, 18 chrome wheels w/ carbon fiber inlays, black projectors, and blue fusion paint and 3-peice spoiler.
