how to change manual tranny fluid from the top? - FirebirdV6.com/CamaroV6.com Message Board
  • how to change manual tranny fluid from the top?
    i've heard of people refilling their manual tranny fluid when they take out their shifter. Can you fill it from up-top inside the car? or do you have to change it from underneath with that fill plug? the problem i have is trying to figure out how i'm going to get the fluid up there in that space? i know you have to use some sort of pump tool to pump it up there, but i dont have access to one. anyhow, is there a way to do it from the topside when u take the shifter off?
    Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
    Re: how to change manual tranny fluid from the top?
    im sure there is a way, because it is open in there.
    all you would need to do is hook a hose to the bottle of tranny fluid and put it in the drain plug somehow, and fill it up.. you wouldnt even need a pump
      Yes, remove the shifter and you can fill it up through the hole.
      If you're doing it yourself, try this:
      -Drain all of the old fluid
      -Get the car on a level surface and remove the top (fill) plug.
      -Put a drain bucket under the trans.
      -Remove the shifter and begin filling through the shifter's hole. It may take a bit longer because the fluid must travel through a small opening.
      -Once the fluid begins to trickle out of the top hole, it's basically full. Reinstall the plug and shifter, then you're ready to go :banana:
      The toughest part is getting back under the car to reinstall the top plug. I usually jack the car up ~slowly~ on the passenger side and slide under. This way the fluid will flow to the opposite side of the trans and doesn't pour out of the opening.
        i appreciate the help. im gonna try it out tomorrow after work. all i need to take out the drain/fill plugs is a 1/2 inch ratchet? or 3/8?
          its a 3/8 hole. just take a ratchet and put a 3" extension on it and youll be good to go
          '99 Camaro Y87 M5 T-tops
          Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
          Car Domain
            let me know how u make out on doin that...i gotta add some to mine i think
            87 Firebird RIP
            96 Camaro RS RIP
            94 Patriot Red 1LE Z28 - Sold
            02 WS6 TA - Sold
              dont see how, unless you dont have a manual.
              manual trannies are completly closed, unless you have a crack/hole in your transmission, you are not low
                You really don't need a pump to do it from under. I just stuck a plastic hose onto the top of my bottles and squeezed the fluid in. Worked like a charm. :)
                1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
                  Im not in the position to agree or disagree with you right now being as i havn't had the chance to take a look. According to other various members on the board however, you can fill it from the topside if you take the shifter off. I hope you can atleast....gonna be a pain to take the console/shifter off to find out i cant do it. can anyone else verify it from experience?
                    yes i have done it. in fact i just did it today when i put my new transmission in. really taking apart the console is not a big deal. its a total of 9 bolts to get the whole console off and then 8 more on the rubber shift boot and then 4 more on the shifter. really easy to do.
                    Car Domain
