ok this a dumd question but i just got to know on my hpp3 i have 2 reading of octane i could put on 87 or 93 i put it on 93 so is ok to run 91 couse thay dont make 93 octane down in cal so what u guys think thanks
dumb question
dumb question
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
Re: dumb question
you should be alright, what the Hpp3 does is advance the timing depending on your octane to give you a few extra HP
Re: dumb question
why do you want to run 91?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: dumb question
Originally posted by slow6why do you want to run 91?Originally posted by 97rs4lifewhat the Hpp3 does is advance the timing depending on your octane to give you a few extra HPOriginally posted by Kal-Elis ok to run 91 couse thay dont make 93 octane down in cal2000 M5 Pewter Firebird [Monsoon stereo]<br /><a href=\"http://www.centerlinewheels.com/sub_wheel.php?mw_id=2\" target=\"_blank\">16\" Centerline Galaxy Wheels</a> . <a href=\"http://www.bfranker.badz28.com/headlightfix/\" target=\"_blank\">Headlight fix</a> . Under dash lighting . Dashmat . Headlight conversion<br />84k miles<br /><br /><a href=\"http://www.cardomain.com/id/tucsonbird\" target=\"_blank\">Cardomain</a><br />Tucson, AZ
Re: dumb question
ok cool thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Re: dumb question
"higher octane gas by itself will not make more power!
Just like more boost by itself will not make more power!
Using higher octane makes it retard from detonation (makes it safer
to turn up the boost).
Some N/Aers prefer to use 87 for their N/As.
The tendancy for lower octane to be less stable and burn faster means that
more chemical energy is used while the charge is expanding in the cylinder before the exhaust valve opens. Fuel burning in your headers doesnt do anything but keep your exhaust hot." Its a waste to run higher octane when not needed.
Situations where you do need higher octane: high compression, boost, nitrous, high mileage motor(because of carbon hot spots), if you are gonna race it hard, or seeing detonation.
Source:
-Sport Compact Car "The Truth, Tuning myths busted"
Volume 18, #6 of June 2006
I've read alot more than just this. But whatever, its your money, do what you want.Last edited by slow6; 07-12-2006, 07:05 PM.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: dumb question
wow slow6 thanks for the heads2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Re: dumb question
Originally posted by bahbut if its tuned for the 93, then it ought to make a difference and give an advantage, its advanced timing or something, idk
just saying, if its not tuned for higher octane, then dont drive around daily driving all the time using higher octane...not really worth it IMHO2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
