My accelerator pedal did not seen to go all the way down some times my car when i push it all the way downs seens really fast and other times is like it has no effect on it an i checked my accelerator pedal and the cable that goes to the trotle body seens very long can this be a deefect from factory and has anyone ever had this problem i have a 1998 firebird 3800
accelerator
:eek: Where is the puncuation? the commas, the periods?!? Grammar? or lack of it!?! My English professor would have a heart attack!
If your throttle cable seems too long then the pedal would go all the way to the floor and you wouldn't accelerate much. If it was adjusted too short then you would be opening the throttle all the way before your pedal reached the floor.
It may be that your car is just sluggish. Your engine isn't just going to respond whenever you hit the gas. A lot of different factors affect throttle response.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
I mean, for lack of a better definition, that it just takes longer than usual to get up to speed. And this depends on a lot of different factors such as mileage, etc...
[ September 26, 2002: Message edited by: Dojo2000 ]</p>~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
also what gear you are in. do you have an auto? if i floor it at like say 45, i don't really go anywhere. it sucks. but if i floor it at 35, my car takes off, because it downshifts. check your air filter, and maybe replace your fuel filter. your plugs/wires/coils can affect this, too.\'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
I think it has more to do with what gear and speed you are at. Your car might not down shift at 45 but will at 40. An auto tranny can be a pain. How long have you had the car? Is it an auto? If its a new car to you it will take a while to learn all the shift points.White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
If its an engine problem then it could be a number of things. What does it sound like when you floor it and nothing happens? A few months ago my car was running sluggish and was making a sound that I can only compare to a gurgling sound. It turns out it was the egr valve so I cleaned that out. A few months later I had a similar problem. I had the fuel system cleaned out and went ahead and had a tune up done after I found out that 2 of the 3 starter coils were bad and replaced all of those along with plugs, wires, etc. It runs fine now. If I had to guess I would say that you have a problem with the fuel system.<b>Black 1996 3.8L Firebird A4</b><br />--------------------------<br />Custom CAI, Flowmaster Dual Exhaust, 160 Deg Thermo, BMR ShockTower Brace<br />JVC mp3 HU, two 12\" Infinity Kappa Perfects, Infinity 6.5\" components, JBL 600.1 & 80.4 amps <br /><a href=\"http://community.webshots.com/album/479229363CPbPiz\" target=\"_blank\">Pics</a>
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
