i went to pepboys to buy a torque (i think that's what it called) bit to open my seatbelt plastic thing. I saw that they have many different sizes and they look similar in size so i couldn't decide which one would fit my seatbelt screw...they are sold individualy ..... does anyone here knows what size i should buy? T45 , T47 , T50 or T55 .... thanks.
what size torque screw driver?
Re: what size torque screw driver?
hmm what i would do is go to sears or something and buy a set of them. they show up a lot on cars nowadays and they're a handy thing to have around'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
Originally posted by bahbig hex key works for that oneRebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
go ahead and get a mixed set of little and big ones. the more you work on your car the more you need them. you need them for parts like adjusting headlights, the fuel pressure regulator, high mount tail light replacement and many other things95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
Thanks guys for your suggestions....Sears is too far from my house so i went to pepboys .... they had a 4 pack which costs $11 and the full set almost $27.... that's a bit too much. so i bought a single pack.......it worked perfectly and my seatbelt glider is installed.... :banana:
Originally posted by xcdarrel17I'm pretty sure it's a T55, but I could be wrong on that.
85% sure
