im goning to change my oil tommorrow and i was wondering how much oil im gonna hve to buy. how many quarts of oil does a 2002 v6 camaro hold? will 0w30 be ok to use?
oil change
Re: oil change
i would use 10w-30 and 4.5 qts2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: oil change
About 5 quarts, and I use K&N HP-1001 oil filters.
Here's a link if you're interested:
http://www.knfilters.com/search/prod...x?Prod=HP-1001
Re: oil change
I use a regular sized oil filter and 5 quarts. Fill it up perfectly. Just buy a 5 quart jug
Re: oil change
PH-3980 Fram Oil Filter is the equivalent of AC Delco's PF-52. It's only the same length and choice for those who add 5 quarts of their favorite motor oil.
The Fram oil filter above however has a black grip coating on it for easier installation and removal. As with any decent filter, just be sure to coat the internal rubber neoprene gasket with fresh motor oil and wipe clean the area where the oil filter screws into the block. This saves you the aggravation of a stuck oil filter when a removal is attempted in the future.
TIP: I like to mark down my next oil change mileage interval on the surface of the oil filter with a nice thick permanent marker. It's a nice reminder when you look under the hood and wonder how much you drive til the next oil change.Last edited by 96RS Alex; 07-15-2006, 10:18 AM.Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
Re: oil change
I bought my 1997 3.8 F-body like a month and a half. When I bought it, the first thing I did was an oil change. The oil that I used was Castrol Synthec 10W-30, but a week ago I read on another forum that Castrol oil is very bad for this car. I really don't know, on the other car that was the oil that I used, and was the best, but obviously is not the same car.
What kind of oil can anyone suggest me? thank you:banana:
Re: oil change
I have a 96 and I use Quaker State High Mileage most of the time. There isn't THAT much difference between most motor oils. Synthetics can tend to make a higher mileage car leak (at least from my experience), but I think if you're looking for highest quality... Royal Purple, from what I've heard on here.Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
