Alternator Underdrive Pulley Discovered - FirebirdV6.com/CamaroV6.com Message Board
  • Alternator Underdrive Pulley Discovered
    Well my alternator went out today on me so I ordered another one through my dad's supplier (he owns a mechanic shop) and I threw it on when I got it this afternoon. I compared the pullies on the stock alternator and the replacement and found the replacement one to have a different size pulley so now I have an underdrive pulley :) . And I didn't have to even buy one from zzp, just had to replace my alternator when it went out.
    Just thought I would give you a heads up on possible benefits of having your alternator die on you, lol.
    http://www.bowtiev6.com/
    Re: Alternator Underdrive Pulley Discovered
    ya most times when I break something i dont normally dont get to mad because then I just have a reason to upgrade. unless its like a motor or sumthing...
      If breakdowns happened at better times, like before I just emptied my account on something else, then I would agree 100%, but with my car, I just spent a boatload on everything I needed to do my new elaborate exhaust and drained the oil and noticed coolant= head gasket. But hey, I guess it did work out b/c now, since the heads are coming off anyway, I'm rebuilding my whole valvetrain + cam. I took it to the next level ;)
      Custom interior...
      TEAM NoVa
        So what's the part number and who makes it? I would like to see a pic of this.
        When mine went died at 209k, I went to AC Delco. I trust AC Delco parts.
        I have yet to do the Big 3 ( heavier gage cable to starter, alternator & battery ). Maybe when my original factory starter gives up the ghost.
        Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
