obd P1652 - FirebirdV6.com/CamaroV6.com Message Board
obd P1652
  • obd P1652
    P1652 Vehicle Speed Sensor (VSS) output circuit
    what exactly does that mean? and how do i fix it?
    Re: obd P1652
    it means either you're VSS is dead or the wires running from it to the comp have a short in them.
      Re: obd P1652
      What kind of car do you have?
      2000 3.8 A4 Pewter Camaro
        Re: obd P1652
        95 3.8L. it comes on and off. I did just install a manual fan switch over the weekend. i wonder if that could be causing it. Also the speedo is working and as far as i can tell is still accurate
        Although i have a worse problem: im getting 15 mpg and its falling. im driving more and more conservatively and my mileage is just getting worse. i got an oil change, fuel injector cleaner, cleaned out my air filter and it got worse. i changed my plugs last summer and i was gone all year so it barely got driven.
        My AC is messed up, it doesnt blow cold air and need to get it fixed but i dont even turn it on. could that still be messing it up?
          Re: obd P1652
          DTC P1652 Cooling Fan Relay 2 Control Circuit
          Dont think your car is liking the fan switch. did you wire it up properly or did you faulter from the write up?
            Re: obd P1652
            i followed all the write ups i found on the net. most of the time the code doesnt come up.
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
