WTF cruise control issues? - FirebirdV6.com/CamaroV6.com Message Board
  • WTF cruise control issues?
    So my cruise control was acting up on a roadtrip...
    it woudl work fine, but if I went up a hill crested it and started going down the other side it woudl shut off.
    then if I turned it back on it woudl shut off like 2 seconds after it kicked on, until I would put car in neutral pump the clutch pedal shut CC off then turn it back on.
    then it would work fine till the next bridge..
    What woudl cause this, I had an issue where my clutch CC switch got misaligned and was only in the on position so I adjusted it and its been fine since.
    can't be same issue or it wouldn't work at all.
    WTF?
