Help! Loss Of Power? - FirebirdV6.com/CamaroV6.com Message Board
  • Help! Loss Of Power?
    I'm cruizin' down the highway at 80-85mph, everything's fine. I stop at red light, and when I take off again, there's no power. It won't rev over about 3500.
    It's a stock '02 Camaro 3800 M5.
    There's no SES light, and no DTC's on the scanner.
    I changed the air and fuel filters, just because they were a year old, but that didn't help any.
    Any ideas?
    2002 CAMARO \"RS\"<br /> 3800/M5/Y87
    Re: Help! Loss Of Power?
    it wont rev or it wont let your drive over 3500?
    2000 3.8 A4 Pewter Camaro
      It run's smooth up to 3500.
      There's just no power.
      Once it hits 3500, it starts missing, and I have to shift to the next gear.
      It feels like a restricted exhaust/clogged cat, but I would expect a trouble code for a bad cat?
        not necessarily. mine didnt blow a code (pos...) it sounds JUST like how mine did when i blew it a year ago. i'll bet if you knock on the cat you'll hear sumpthing rattlin around...
          Im 99% sure its your cat. I pulled my car out of service for a clutch master cyclinder and the same thing happened on my 2001 3.8 m5. It wouldnt for the world crank over 3500. turned around and they found a bad catalytic converter. You can get them at your local muffler shop. ;-)
          Go Fast or Dont Go
            Yea, something like that is likely to happen after highway cruising, and then coming to a stop because of the constant heat for a long time, and then the change in flow, and motion of the exhaust. Same thing happened to me.
            Custom interior...
            TEAM NoVa
              http://cgi.ebay.com/ebaymotors/2-5-M...09441491QQrdZ1
              Heres what I got when mine went bad sounds much better now also
                Well, I was planning on changing the exhaust system anyway, so I guess I'll try that.
