as the title says i need to know where the port is where i recharge my a/c. i already did a search and i know all about recharging, but i dont know where to plug in! pics would be real helpful, or a really good description. thanks!
where is the port where i recharge my a/c?
Re: where is the port where i recharge my a/c?
if you have a 98+ it is right next to the rad
edit* anyways, you cant put it on the wrong port, it wolnt fit
look at my rad cap, you will see a little black "knob" that is the refill port
so its the port that is actually "on" or "sticking out of" that silver cannister just above and to the left of the radiator?
thats where i thought it was... but wanted to be sure.
correct me if im wrong. ill be recharging it today after work... around 6pm EST.later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
If your using the proper gauge set you connect the high pressure gauge to the high side fitting which is located in the smaller A/C line running to the radiator. The capped fitting is next to the radiator. You need to remove the cap to connect the line.
The low pressure gauge and refill line attached to the low pressure fitting which is located on the reservoir/accumulator. Again, remove the cap to connect.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
if you can, do not refill on the high side. you might cause your high side valve to leak.
ok, thanks guys...
the kit i bought says to use the valve and refil both on the low pressure port... so thats what im gonna do. thanks for the help... looking forward to a sub 90degree cabin!!later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
