I have question about this washer fluid tank I would like to know is it necesarry to have because I rarely use it and whenever I do it just makes things worse because only part of the windshield is clean so what I would like to know will removing the windows washers fluid tank prevent me from passing inspection any suggestions will be appreciated
washer fluid tank
Re: washer fluid tank
i removed mine. You could just drain it. Or you could remove the whole thing for like a pound extra. There is a plastic black piece that blocks the radiator of air.. I gladly ripped that out too!2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
its right underneath the washer reservoir... i need to remove the washer pump and lines now
i also need to do some experimental testing now2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 weeks ago
