its suckin air in the oil filler spout dipstict tub valve cover where pcv goes and other valve cover hole where the tube that goes the air duct . idols about 2200 rpms i can plug the valve covers holes and idols fine. thanks guys
3.4 help
Re: 3.4 help
so the oil fill spout is sucking air in? I would suggest replacing the PCV valve then. its only like a $3 part and is the closest vaccume part to replace.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
Re: 3.4 help
Your high idle RPM is from a vaccum leak.
The PCV system, through the use of manifold vaccum, is supposed to draw vapors and combustion bypass gasses into the into the intake manifold to be burned off in the combusion chambers.
If you remove the vaccum line from the PCV valve and plug the line (so that you don't have a vaccum leak), and you still have vaccum drawing from the locations/components you listed, then my guess is that the intake manifold probably has a leak on the underside (in the lifter valley area) which is providing an unwanted vaccum in the interior of the engine, causing the symptoms that you describe.
Do you have any other driveability issues, like hesitations, surges, oil consumption??Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...1 day ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
