ok so I have no turn signals..... they just stay solid.....anyone?
No Turn Signals...
Re: No Turn Signals...
blinker relay is bad, maybe bulbs too, its under your dash steering wheel side, a little circle metal thing clipped to your right hand side, there are actually 2, but one is for your hazzards the hazzard one has yellow bands on it, thats not the one
its like $2 or 3, if you go to a parts store it will be called a thermal flasher, pretty generic, but it looks like the one with the yellow bands on it, but its the other one, but its clipped to the frame kinda, i'm doing a bad job explaining it, but if you need a pic let me know
If you replace the relay with an electronic relay unti from Autozone, the one that is quiet, DO NOT..... put it in the holder the other one was held with. The plastic case on the new relay gets crushed and it makes it so it won't work properly... I found this out..... I took it out of the holder, and haven't had a problem since.2000 Camaro 3.8 <a href=\"http://www.cardomain.com/ride/2040383\" target=\"_blank\">http://www.cardomain.com/ride/2040383</a>
I'd try whatever's easier first, I have a 96 so I don't know how hard it is to change the turnsignals on your car, but the relay is much easier on mine, and since both are relatively cheap, just try the the relay first.Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
I had this happen to mine - what the problem is is the actual turn signal light is fried and needs to be replaced - the computer notices this and that's how it informs you is by keeping the turn signal solid instead of blinking - replace the turn light and it will go back to normal.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...9 hours ago
