I have the Front Turn signal out.. is it easier to come in from the top.. Like I did the Fog Light or is it better some other way? [img]graemlins/dunce.gif[/img]
Easiest way to change out a Turn Signal
98 Camaro 3.8L black with T-Tops, K&N Air fliter, MSD Coil packs, More mods to come<br />web site <a href=\"http://www.wayug.com\" target=\"_blank\">www.wayug.com</a> \"are you down enough\"Tags: None
I went in from the bottom on my 99. There are like 5 or 6 bolts you have to take out of the plastic air dam thingy to get to it. It was actually sort of a PITA.
I didn't see anyway to get to it from the top. Although I didn't spend a lot of time looking so there may be.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
I was reading the search files. and was wondering about the Head Light removel idea. did it work?98 Camaro 3.8L black with T-Tops, K&N Air fliter, MSD Coil packs, More mods to come<br />web site <a href=\"http://www.wayug.com\" target=\"_blank\">www.wayug.com</a> \"are you down enough\"
ok after I took apart almost the entire underbody I found out that there is a service flap that will open.. it is in front of the tires remove two screws and your in. now if I'd only seen these before I decided to take apart my camaro. HA Live and learn I guess [img]graemlins/dunce.gif[/img] [img]graemlins/crybaby.gif[/img]98 Camaro 3.8L black with T-Tops, K&N Air fliter, MSD Coil packs, More mods to come<br />web site <a href=\"http://www.wayug.com\" target=\"_blank\">www.wayug.com</a> \"are you down enough\"
<blockquote>quote:</font><hr>Originally posted by Bebo0001:
ok after I took apart almost the entire underbody I found out that there is a service flap that will open.. it is in front of the tires remove two screws and your in. now if I'd only seen these before I decided to take apart my camaro. HA Live and learn I guess [img]graemlins/dunce.gif[/img] [img]graemlins/crybaby.gif[/img] <hr></blockquote>
could you get to the blinker through that flap?
Mine looks like it has metal over the bottom and I couldnt get at the bulb :(
