radiator cap - FirebirdV6.com/CamaroV6.com Message Board
radiator cap
  • radiator cap
    change the rad. cap with a CST t-16v -16lbs from auto zone and when it reaches normal temp. it boils over and empty the reservoir tank , put back the old one (stant 231-16lbs ) and it's works ok, the only differnce is the CST is T-16v and the STANT is231 both 16lbs. the old one says vented , maybe that the diffence between the two
    Re: radiator cap
    what is 16v the 231t is the temp at witch it opens
      Re: radiator cap
      sounds like a bad cap, take it back and get another one.
        Re: radiator cap
        i realy don't know , thats what the cap says all i know is i had to put the old one back to the radiator. so those number and letter mean something.
          Re: radiator cap
          i got a new cap just like the old one and it also says vented and notice the center cap is loose , compair it with the old one and it's loose too .(strant brand )
