change the rad. cap with a CST t-16v -16lbs from auto zone and when it reaches normal temp. it boils over and empty the reservoir tank , put back the old one (stant 231-16lbs ) and it's works ok, the only differnce is the CST is T-16v and the STANT is231 both 16lbs. the old one says vented , maybe that the diffence between the two
radiator cap
Re: radiator cap
sounds like a bad cap, take it back and get another one.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
