Tracking down coolant - FirebirdV6.com/CamaroV6.com Message Board
  • Tracking down coolant
    Well the back story is that recently I had to replace a lifter in my engine. After getting everything back together I still have one small problem holding me back from racing.
    I now have a terrible coolant leak that only occurs when the car is running at reg operating temp. Once the car gets warmed up coolant flows out at a high rate. Puddles quickly form on the K-member.
    This is a new water pump and there is no leak from the weep hole. All new gaskets were used also.
    Here is where I loose track of the leak.
    http://pics.xs.to/pics/04086/P1010008.JPG
    This is the left side of the WP. If it wasnt raining out I would take off the alt and get some better idea's but right now all I can do is play desk mechanic. Any idea's?
    98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
    wow, i was just about to post, i have the exact same problem. i flushed coolant about a month ago, but i dont think that is it b/c it just started leaking a few days ago, and it only leaks when the car has been running a little while.
    <a href=\"http://www.cardomain.com/memberpage/483076\" target=\"_blank\">http://www.cardomain.com/memberpage/483076</a> <br />TSP rumbler, straight pipe, corvette servo. <br />Soon - 3.42+lsd,headers, cai,
      Yeah, the other day I only drove about 3 miles down the road but the car got up to normal running temperature and it started to leak. I could smell it through the vents, and when I stopped I saw a fairly significant amount of fluid leaking from that area. I really want to fix this so I can start driving my car around normally.
        it may be a new pump, but id say check the gasket. Did you scrape the old one off completely?
        Does it look like its comin from around the head at all?
          Well again today I didnt get a chance to dig around any more. I had to work this morning and then it has raining all day here. Garage is actually flooded. The pump is new, less than 6,000 miles on it. Yes I cleaned the gasket off, scraped then used gasket remover spray. As soon as it dries up some more outside I will get some more stuff out of the way and try to track it down a little better.
            cool, i hope its not the waterpump, i will be checking it out probably tomorrow or tuesday, let me know what you find if you're first nathan
              Alright well from further I am even more baffled now. The "leak" from before has grown 10x worse. Before it would not start leaking until the engine warmed up some, now as soon as I start the car the coolant starts flowing. Not dripping, almost a steady thin stream.
              Here is where the coolant finally falls from.
              http://pics.xs.to/pics/04082/leak1.jpg
              This picture is taken from drivers side of car looking from back to front of the engine.
              I surely hope their isnt a bad seal inside the engine, I do not want to pull it all apart again.
                can you get a picture of that same spot, but zoom out some, like farther back so you can see teh whole area?
                could it be a freeze plug?
                  Sure, tomorrow I will hop under the car and see what I can get. I never touched the freeze plugs but it seems weird that they would open up so much after working on the upper engine. I am betting that either that I did not put a hose/connector in deep enough, or a gasket was a POS right from the get-go.
                    6 days ago
