o2 sensor. Bank 1 sensor 3. - FirebirdV6.com/CamaroV6.com Message Board
  • o2 sensor. Bank 1 sensor 3.
    I have 4 o2 sensors. Is bank 1 sensor 3 the Precat or Post cat?
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    Re: o2 sensor. Bank 1 sensor 3.
    pre i think
    why? are you getting a code?
    this is not advanced tech
      Yeah Im gonna toss the flag on this one.
      Moving to general tech.
      10 yard penalty, repeat first down.
      1997 Dodge Viper GTS
        ok so its 1st and 20. any suggestions"?
          throw the ball! passes are always exciting!
          Do you have a question?
          You dont NEED either the pre-cat or the post-cat. All they do is
          make sure the cat is working. I deleted mine because I have a semi-gutted
          high-flow cat
            yea are you getting a code or what is the problem, then we can figure out if we need to run the ball on 1st down or go big with the deep pass.
            http://www.bowtiev6.com/
              I am pretty sure that the o2s are number like this:
              Bank 1:
              Sensor 1 - manifold
              Sensor 2 - Pre cat
              Sensor 3 - Post cat
              Bank 2
              Sensor 1 - manifold.
              But I am not 100%.
              Trial and error works pretty damn well.
              Start with post cat.
                http://forum.camarov6.com/showthread.php?t=69337
                  A Bad o2 won't really cause that.
                  I would say get your MAF sensor replaced, then really start eyballing the ignition system.
                  It seems like ignition to me. I dunno why.
                    well i did replace both of the manifold o2 sensors.. they were pretty bad. since i did the fuel pump and the o2 sensors in the manifolds, the air/fuel metering code went away and so did all the other codes.
                    the only code i get now is p0146 for bank 1 sensor 3 no activity. i have no o2 sensor there since i have no cat.
                    but i still get a misfire under load. now no codes are showing up for it.
                    im about to buy a new freak'n engine. lol
                      Check out your coils and ICM.
                      Check fuel pressure at the rail, on and off throttle.
                        if i bought auto tap would i be able to better diagnose the problem? i've been wanting it for the longest time now anyways..
