Is there a low temp fan switch for the 3.8? - FirebirdV6.com/CamaroV6.com Message Board
  • Is there a low temp fan switch for the 3.8?
    It would seem so much easier to swap a low temp fan switch in with a low temp thermo, rather than fooling with a manual switch. What about the Hypertech switches for TPI cars? The wire looks a little short, but otherwise it looks like the one on my engine. It is right below the TB right?
    Arctic White \'02 Camaro<br />3.8, 5spd.
    I would bet with a simple resistor you could change the reading of the thermistor to the computer to make it THINK its really 20-30degrees hotter than it trully is.
    The good would be that you would have fans which kicked on earlier [img]smile.gif[/img]
    The bad would be it would kick itself out of warmup cycle a bit early :(
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      Rksports carries a automatic fan switch. You can set the fans to kick on from 145 degrees to 245 degrees. I think it runs at $149.99. Not for sure.
      2000 V6 Camaro(bought brand new)
      5 speed
      Project: Unreal
      Will give details when fin.
      5 speed
      Project: Unreal
      Several Mods..:naughty:plus Nitrous=WEEeee:banana:
      2007 Suzuki GS500F :D
      Daily driver
      2007 Chevy Aveo 5
      Mods K&N air filter:excited:
      www.guardiansworlds.com
        gee $149 thats alot of money,no wonder rksport sux :mad:
          <blockquote>quote:</font><hr>Originally posted by TheCardinal:
          <hr></blockquote>
          Ive tried this and it doesnt work, just ammending my post from a long time ago by saying it doesnt work...
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
