Royal Purple. Is It Good - FirebirdV6.com/CamaroV6.com Message Board
  • Royal Purple. Is It Good
    well im coming up on another 3000 miles cycle and its time to change my oil.
    i was thinking of going royal purple synthetic. but will it really make a difference? i know i can never go back to regular oil so i was wondering of its worth the extra money
    Re: Royal Purple. Is It Good
    if you have done regular oil the whole time I wouldn't switch to royal purple. Royal purple is good for new engines where it is the only oil it will see. Adding it to your engine now will cause you most likely to have leaks because it will find the holes that the regular oil couldn't fit through do to thickness.
    http://www.bowtiev6.com/
      i have used royal purple for a while in everything antifreeze oil rear ends auto trannys that **** is great! i watched a video of a camaro SS i think gaining 9WHP from swapping fluids to royal purple granted that ss was prob. way overdue for a oil change it was still impressive 9whp! from fluids anyways royal purple is the ****!
      http://royalpurple.com/video/video.html
      2nd video down
      2001 Camaro 3.8 A4
      1991 3000GT VR4
      2001 Mitsubishi Eclipse GS
        I've also been using Royal Purple now for about 30,000 miles on my car and I have no leaks. If you use Royal Purple you don't have to change your oil every 3,000 miles. Its good for at least 5,000 miles.
        <a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
          UMMM, why cant you go back with regular oil if you use royal purple?
            switched to royal purple at 137k, it was on dino before, no leaks, havent lost a drop in 2k or so, but just keep in mind to run some cheap supertech or whatever synthetic for 500 miles or so beforehand and then change it again to flush out the dino
              i love supertech...so cheap
                whats supertech?...and why cant u go back to using regular..i heard that from a bunch of mechanics i just dont knw why
                  supertech is wal-marts brand. the super-tech filter say they filter 2x as much as another filter.
                    its a waste of money
                      what? suprtech? or royal purple?
                      I'm just using supertech to break my engine in
                        Royal purple
                          victimization's right. you can spend all the money on oil that you want but when it comes down to it, nothing is more important than every 3k. how many people on this board have over 100k and all they did was change the oil? :wavey: just change the oil every 3 and thats all ya need. nitpicking b/w oils is a waste of time.
                            not according to thatoilguy.com or whatever the site name is
                              Royal Purple will last longer than 3k miles.
