Shimmy @ 50mph - FirebirdV6.com/CamaroV6.com Message Board
Shimmy @ 50mph
  • Shimmy @ 50mph
    I just recently replaced my brake pads, and ive noticed that around 47-54 MPH my steering wheel shimmys right to left quite bad. It goes back and forth about 2 inches each way and becomes very annoying. If i slow down or speed up from 50 it goes away. Could this just be the new brakes pads needing to be worn a bit? I didnt notice this problem till after installing the brakepads
    1998 Chevrolet Camaro<br /> <a href=\"http://www.cardomain.com/ride/2101276\" target=\"_blank\">http://www.cardomain.com/ride/2101276</a>
    Re: Shimmy @ 50mph
    not saying this is your prob, but there is a proper procedure to breaking or bedding in new pads
      Re: Shimmy @ 50mph
      yea there is a way to break pads in, also could be a wheel that needs balancing. Also check all your lugnuts to make sure they are tight. A couple loose lugnuts can cause your symptoms and also cause you to loose the wheel/tire while driving.
      http://www.bowtiev6.com/
        Re: Shimmy @ 50mph
        Usually those shimmies at around 50mph are due to worn tires that need balancing. Whenever mine have done that, re-balancing the tires has solved the problem.
          Re: Shimmy @ 50mph
          Theyre BRAND NEW Wheels/tires
          only 200 miles on them
            Re: Shimmy @ 50mph
            So you got them balanced, right?
            <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
              Re: Shimmy @ 50mph
              Could you have knocked a wheel weight off when taking the tires off?
              If definitely sounds like a tire balance issue.
                Re: Shimmy @ 50mph
                That's a good thought, be sure to check for that. If the weights are there and they didn't shimmy before, then it must be something with the brakes.
                  Re: Shimmy @ 50mph
                  while they're balancing, tell the techs to shake the front end. basically they'll try to move the front wheels side to side and in/out at the top. if theres movement then you got worn suspension parts. shouldnt cost nothin and takes all of 2 minutes
                    Re: Shimmy @ 50mph
                    Same problem here. Whenever I get them balanced it goes away, but comes back... Then I do another balance and it goes away again. Any guesses as to what that is? Bent wheel?
                    Red 1998 Camaro<br />Mods so far=<br />K&N
                      Re: Shimmy @ 50mph
                      could be a hard spot in the tire...
                      I would take it to a dealer who has a road force machine so they can inspect your steering and suspension, check the wear, balance and hard spots of your tires. could be a bad wheel too. sucks they are new.
                      2000 3.8 A4 Pewter Camaro
                        Re: Shimmy @ 50mph
                        Well theyre under warranty. Ill check to see if all the balances are still there tommorow.
                          Re: Shimmy @ 50mph
                          I had the exact same problem. you need to have your discs re-surfaced. it is really cheap and it fixed the problem. a local place did mine for like 6 dollars each.
                            Re: Shimmy @ 50mph
                            but arent they new brakes/discs?
                            jeffkiernan , do you mean rotors?
                            edit: added: "jeffkiernan"
                              Re: Shimmy @ 50mph
                              is this a problem that happens when you are braking?
