I just recently replaced my brake pads, and ive noticed that around 47-54 MPH my steering wheel shimmys right to left quite bad. It goes back and forth about 2 inches each way and becomes very annoying. If i slow down or speed up from 50 it goes away. Could this just be the new brakes pads needing to be worn a bit? I didnt notice this problem till after installing the brakepads
Shimmy @ 50mph
Re: Shimmy @ 50mph
not saying this is your prob, but there is a proper procedure to breaking or bedding in new pads2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Shimmy @ 50mph
yea there is a way to break pads in, also could be a wheel that needs balancing. Also check all your lugnuts to make sure they are tight. A couple loose lugnuts can cause your symptoms and also cause you to loose the wheel/tire while driving.
Re: Shimmy @ 50mph
Usually those shimmies at around 50mph are due to worn tires that need balancing. Whenever mine have done that, re-balancing the tires has solved the problem.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Shimmy @ 50mph
Originally posted by Rob BellUsually those shimmies at around 50mph are due to worn tires that need balancing. Whenever mine have done that, re-balancing the tires has solved the problem.
only 200 miles on them1998 Chevrolet Camaro<br /> <a href=\"http://www.cardomain.com/ride/2101276\" target=\"_blank\">http://www.cardomain.com/ride/2101276</a>
Re: Shimmy @ 50mph
Originally posted by SpeedingFirebirdCould you have knocked a wheel weight off when taking the tires off?
If definitely sounds like a tire balance issue.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: Shimmy @ 50mph
while they're balancing, tell the techs to shake the front end. basically they'll try to move the front wheels side to side and in/out at the top. if theres movement then you got worn suspension parts. shouldnt cost nothin and takes all of 2 minutes2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
Re: Shimmy @ 50mph
could be a hard spot in the tire...
I would take it to a dealer who has a road force machine so they can inspect your steering and suspension, check the wear, balance and hard spots of your tires. could be a bad wheel too. sucks they are new.
Re: Shimmy @ 50mph
Well theyre under warranty. Ill check to see if all the balances are still there tommorow.1998 Chevrolet Camaro<br /> <a href=\"http://www.cardomain.com/ride/2101276\" target=\"_blank\">http://www.cardomain.com/ride/2101276</a>
Re: Shimmy @ 50mph
but arent they new brakes/discs?
jeffkiernan , do you mean rotors?
edit: added: "jeffkiernan"Last edited by slow6; 07-28-2006, 12:56 AM.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Shimmy @ 50mph
is this a problem that happens when you are braking?
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...8 hours ago
